Intellipro vsf and solar touch - Pump Address Display Not Active message
DJSapp
0
May 6, 2014
7
NorCal
I have an intellipro vsf and solar touch controller. Whenever I need to make a schedule change on the intellipro, or adjust the clock, this infuriating pump address display not active message keeps popping up every couple seconds. I know it's connected to automation, I know what the message means, but the solar touch doesn't trigger anything during normal winter operations so I believe I have to make schedule changes from the pump. How do I get this message to shut up for 30 seconds so I can make the adjustments I need? It pops up every 5 seconds and I can't even adjust the time for DST before it flashes and resets!
Disable the SolarTouch Controller and it will release the pump from automation so you can adjust the pump...
