IntelliPH not powering up IntelliChlor
Andome
38
Palm Bay, FL
Pentair Intellichlor IC-40
Another huge thank you to this group saving me a couple hundred once again! I found my IC to be non responsive, which scared me because it was just replaced a few months ago. I powered everything off and restarted it, no luck there. Powered everything down again, and plugged the IC40 directly into the Easy Touch and then it worked normally. So I knew the IPH was faulty. I did some reading on this wonderful site, and found the issue and the fix pretty quickly. Just got it all put back together and it works perfectly! hopefully it stays that way.
On a separate note, I know this failure is pretty common. I noticed mine right after I realized the water level was too low( more bubbles than usual were coming out of the returns). Could this have been a contributing factor?
