- Nov 30, 2008
- 338
duraleigh said:I struggled with that at first, too. A pump pushing no water is doing less "work" than a pump pushing a lot of water. Hence, as PSI rises, electrical consumption actually goes down on a continuous speed pump.
For me, that's not intuitive until you work with it a time or two.
JasonLion said:Just how slow you can run the pump varies from pool to pool. You need to maintain enough flow to keep the SWG happy, so that is probably the limiting issue in your setup. Others might not have that particular issue.
You can work around the "not skimming" problem by speeding up the pump for 10 minutes every couple of hours. Of course, to do this you may need a fancy timer or an automation system that supports many different pump run times with different speeds.
