I am having solar panels installed this month and I'm trying to figure out how to correctly setup everything.
I will be using a Pentair Intelliflo 011018 pump, Pentair Solar Touch controller for the solar panels, and an AutoPilot Digital 220.
From what I understand, the Solar Touch controller will control the Intelliflo based on heating/cooling set points which could start, stop, or adjust the speed of the pump at any time. I know the AutoPilot has a built in safety feature that only allows it to operate when there is flow. However, I would prefer not to solely rely on this safety feature for daily use. Also, because the Solar Touch controller will have various run times based on the time of year, it seems as though I would always be chasing the SWG output setting.
This is what I was thinking...
Wire the Intelliflo to constant power, wire the Solar Touch to control the Intelliflo, and setup the AutoPilot on an external timer or internal timer if there is one.
Any input would be great!
