Hi,
My intelliPH controller unit was replaced due to the common problem of the connector being fried. Before that replacement I couldn't set the chlorine output of the IC40 through the IntelliPH controller and everything went through the IntelliCenter/ App. Now I can set the chlorine output at the IntelliPH controller and that is the chlorine output which gets routed to the IC40. I can also set the chlorine output in the App/ IntelliCenter but that goes nowhere. I haven't found a way to configure it correctly so I can set the chlorine output through the App again. Has anyone experienced this before?
Thanks!
Thanks!
