If we assume a DMH level of 200 ppm, then there is no way to maintain adequate bromine levels and stay within the state mandated regulations.
The best you can do is keep the bromine as high as legally possible with some margin to avoid going over the legal limit.
Dropping the DMH below 80 ppm would allow you to maintain an adequate level without weekly "Shocking".
Do routine OCLTs to see if you are maintaining adequate bromine.
You can get tests for DBPs if you are concerned about those.
Does your Health Department require testing for bacteria or DBPs?
The below is for drinking water.
Total trihalomethanes (TTHMs) include chloroform, bromoform, bromodichloromethane, and dibromochloromethane.
The Maximum Contaminant Level or MCL for TTHM is 80 µg/L (equal to 0.080 mg/L).
Haloacetic acids (HAA5) include many compounds; currently, five are included in the drinking water standard: monochloroacetic acid, dichloroacetic acid, trichloroacetic acid, monobromoacetic acid, and dibromoacetic acid.
The MCL for HAA5 is 60 µg/L (equal to 0.060 mg/L).
Monitoring for DBP involves testing for two types of DBP at the same frequency: total trihalomethanes (TTHM) and five haloacetic acids (HAA5).
Be sure to order test kits from drinking water testing laboratories to cover both types of DBP, and follow the sample collection procedures carefully.
dec.vermont.gov
