IntelliCenter install firmware
colonelkirby
166
DFW - Plano, TX
Pentair Intellichlor IC-60
I have an install happening later this week. I have had the personality kit in storage for quite some time so I am sure its firmware will need updating. Will this install need to go through a stepped install of various firmware patches or can it be patched to the latest firmware in one shot?
TIA
Todd
I'm going to ping @rstrouse - as I am not 100% certain, and he may know the answer to this exactly.
I believe the personality kit is just an expansion board with additional valve/relay connectors. I don't believe there is any sort of chip on it that would have firmware associated with it. It attaches to the main board and then the main board recognizes it.
The main board will need a firmware update for sure. So install the personality kit, fire it up, and then update the firmware for the Intellicenter.
--Jeff
If the firmware is less than 1.047 you will need to update it to 1.047 on a USB drive. After you do that, then it will detect a new firmware for 1.064. If it is greater than 1.047 it will detect the firmware in one shot and update to 1.064. The firmware for 1.047 can be found here.
