I'm trying to figure out if this is a solvable problem or not. I am brand new to all of this. Last night I tried to heat up the spa for an hour or so but it is cold out and the IntelliCenter freeze-protection clicked on after 15 min. That does 2 things: turns off the spa/heater, and pumps a bunch of cold pool water into it. I was confused at first why the heater quit so I restarted the spa/heater and it started to heat up again (5 degrees down from where it was). 15 min later the same thing happened and I decided to give up on the idea and let everything ward off the freeze. So it seems I can't heat the spa up when temps are below freezing currently. But I also don't want the pool freezing up
What I'd really like to be able to do is disable freeze-protection for an hour or something while the spa is in use, then have it come back on when done. Possible? What do people do when it's cold outside like this? Thanks!!!
