Bumping this thread as it always seems to end...
Has there been a way using the pentair IntelliCenter Control System Pool Cover Expansion Card (P/N 522039Z) to monitor the covers position if it's not a coverstar cover? I have an integra cover on my fiberglass leisure pool.
Would be nice to shunt fountain and waterfall operation and lower salt Gen output while cover is closed.
Easiest way would just be a magnetic reed sensor to relay to the intellicenter that the cover is "open" or in a fully unclosed position.
The released version of the manual shows for a digital encoder to be setup on the non motor end. Can I get one to use on the integra? As it also shows that the analogue inputs are "not used"... Which presumably would be needed for a simple reed switch. Not sure if they are defeated or just not used with encoder wiring.
Any help would be awesome.
I program automation subsystems for a living, So I should be able to figure it out.
Thanks in advance.
J
Thanks in advance.
J
