Hi - After reading much on TFP and having been dumping $$$ in chlorine all summer, I have decided to go with an SWG. I was thinking of going with the Hayward W3AQR15. I have a 16,000ish gallon pool and this is a 40K gallon Cell, but it is actually cheaper on Amazon right now that the 25K cell system. Also have questions on my set up, so here are all my questions:
- Does it matter if the Cell is 40K gallons and my pool is 16K gallons? If not, are the 25K gallon cells the same size so I can buy that as a replacement down the line when I need one?
- I am the second owner of the house - how can I know if I have any copper lines?
- I have a copper heater - is that a problem?
- I plan on installing the SWG cell in an upright/vertical position (yellow highlight) in the picture below
- Plan on installing the flow meter on the bottom horizontal section - highlighted in blue/purple in the picture
- Plan on installing a sacrificial anode in the horizontal section just before the heater - highlighted in red in the picture
- When installing the controller - seems like it needs to be connected to a timer to turn it on and off when the pump is running - so that is not the job of the flow meter (is the flow meter a protective thing/failsafe?)
- Is this really as easy as it sounds - a few PVC cuts, hang the controller and make the electrical connections?
