geekgranny said:
I'm not intending to be mean or silly. If the pool/spa system causes so many problems, issues, and financial costs if one wants to use it as a "real" spa, why do builders and/or owners continue to do this combination? Are owners lead to believe by PBs that they will have a heated spa to enjoy whenever they want? I just don't understand. :?
gg=alice
I don't know why I am only seeing this 2 months after the fact. :lol: I visit this website every day...
I would not give up my spillover spa for anything. It has it's advantages and disadvantages I guess.
On the pro side:
You never have to worry about water chemistry. It is always fresh water. (Assuming your pool is clean. LOL)
They are much better looking IMO, because of how they are integrated into the landscaping and stonework of the pool area.
When they are raised up a bit, and you sit in them and look at the pool, it feels like you are at a vacation paradise
They are fairly cheap to add to an existing pool and even more cost effective to build in while building a pool.
A gas pool heater that heats a pool 1 degree an hour can usually heat a spa 1 degree a minute. So heat times dont take too long.
On the con side:
They aren't very theraputic at all compared to stand alone hot tubs / spas... Stand alones are absolutely amazing!!!
If you live in the NorthEast like I do, you need to close the spa when you close the pool. A lot of people love using their hot tubs in the winter.
They are a bit more expensive to keep heated and you can't keep them heated all the time.
If there is a plumbing problem the surround sometimes needs to be dug up to get to the pipes.
Anyway, all the being said, I think both are amazing
I never have a problem with keeping the spa heated because the temperature in the summer never gets below 75 - 80 degrees. Usually higher.
So it only takes about 25 minutes or so to bring it to 104. I can live with that. If Im having a party, I make sure my pool is heated properly (85 or higher) and then just leave the spa on all day long. The only downside to this is any leaves that blow in will not be pushed to the skimmer by the jets since the jets in the pool will be off.
For arguments sake, I know a few people with stand alone hot tubs. They love them, and they seem great. But they are always fussing with the water quality and they don't normally keep them at temp. They turn it on a bit before they get in to heat it up.
