We had this pool last year and did get it in balance and clear, using all of the great threads in this forum. This year I hoping to get things in balance more efficiently. Currently filled and working on filtering out the rust. I am cleaning out the filter every couple hours.
My question is What to work on first? From reading I need to get Chlorine in ASAP and should start by shocking the pool, but should I lower the PH or alkalinity first? or deal with it after the shock? OR maybe a better question is what order to manage levels?
Then should will Pro Team metal Magic help filter out the rust or keep it "hidden'? I think it holds the rust in liquid form but I think I would rather have it precipitate out. Then I could filter to take a week and filter it out as best i can?
Test Kit: EasyTest Strips 7 in 1
Total Hardness: 1000 or higher (that is as high as the test kit goes)
FC ppm: 0
TC ppm: 0
CYA: 0
Alkalinity: the color was close or at the 180 marks so (120 and 180)
PH 7.8
Chemicals I have on hand: I can go to the store easily.
Muriatic Acid: 31.43%
"Shock": 12.5%
CYA 100%
Dichlor: 97% (Pro Team Zipchlor)
PH up:
Pro Team Metal Magic
Inital readings:
FC ppm: 0
TC ppm: 0
CYA: 0
PH 7.8
"Shock": 12.5%
CYA 100%
PH up:
Inital readings:
