So, the wife mentioned she wanted to get a pool for this summer, and gave the go ahead on purchasing. I have done weeks of research on above ground pools (not getting an in-ground) and spent lots of time in the yard to determine locations. However, I do my full diligence before getting into a project. I don't want to give up any space in the backyard, as it's very very hilly, and the area up top of the hills are the only place for the kids to run around. So, the only other option is our side yard, which is basically on the side of the house behind our garage. I checked our local restrictions and only saw something about being 7' away from property lines, nothing about structures.
So, I went ahead and marked out farthest locations of an 18' and 21' size. I had to be careful to stay away from an a/c unit. At this current time, the outside of the blocks are measured 3' away from the a/c unit and 1 1/2' away from the gutter on the garage. We also have to contend with having a french drain pipe system, in which you can see where the stones are that cover this.
Am I trying to fit something into a space that shouldn't be? The 18' would "fit" just slightly better, but I don't want to regret not getting a 21' if it can work...
If this can work, I have pieced together from various places: a 21' x 52" pool, a j-hook liner, a de filter+pump, skimmer/return kit, and a ladder - total of about $1700. I hope it's standard for the pool to have a skimmer cutout (the photos were like stock photos), but I am not sure if it's square or wide...
My opinion is the 21' would be a very tight fit, while giving us 3' between the outside and a/c unit and 1 1/2' between the outside and the garage. I am mostly worried about the french drain and what impact this would have if we dig down right at the outside of the stones...
My photos were apparently too large to attach as files, so I hope this works:
New item by Peter Yeaney
photos.app.goo.gl
photos.app.goo.gl
