I have an inground gunite pool with a built-in spa and caretaker system. Both the pool and spa are leaking 3/4" -> 1" of water per day.
I performed the "bucket test" and validated water loss is the same in the pool and spa, and that the water loss is the same with the pump ON and OFF.
If I understand correctly, this implies either a leak on the suction side or in the structure (drain, sweep, light, skimmer, etc).
I hired a professional that tested the suction side, the skimmer, and the pool sweep return. He told me no leaks were present there and recommended I tape the conduit in the pool light.
I've been looking for leaks with dye around the lights, caretaker returns, and main drains, and I cannot find any leaks.
Questions:
1. Is a 3/4" -> 1" per day leak fast enough to find with dye?
2. I don't see any epoxy or tape around the conduit inside my light (light removed), but I don't see any leaks there with dye either. Should I see a leak with dye when a leak that slow?
3. What's the expected behavior from the dye around a hole/leak in the gunite? Would it settle there, or draw in?
Any thoughts or suggestions appreciated at this point. Cheers!
Questions:
