Inground Fiberglass Pool floor bulge. Help!
Blooze
0
Jun 21, 2016
9
Southern OK
We are into our third year at our current home with a 15K gallon kidney shaped fiberglass pool that was put in 10+ years ago. We opened it last month and noticed last week that we have a bulge about 1" tall, about 18" wide tapering down from the high spot, and about 8-10' long coming from just right past the bottom curve of the side going out towards the middle of the pool and running lengthwise from there. It sounds hollow to me in a couple of spots and flexes a bit there. We do not have a hydrostatic valve as far as I know unless it's under the main drain of the pool. We also do not have a sump pipe to remove/check groundwater levels. I believe what has happened is we have a dip in the yard near the deck that has always been there. It's where the bulge starts and we noticed that it's washed out under the deck in this area as well. The grass had it pretty much hidden. The sides aren't bulging at all, but there seems to be a hollow spot (when I wrap on the wall) a couple inches wide down the side that corresponds to where the bulge starts.
The big kicker is we are having to put our home on the market by the 1st of July due to a job change and because of our somewhat remote location there isn't much advice or experience it seems with this issue from the local pool places (it's $700 just to get someone to come from the nearest large city). Obviously we have to disclose the issue, but we are at a loss as to whether we should try to fix it, get estimates to fix/fill and discount the home, etc... Scouring the interwebs has led us to believe it would be expensive to fix and we have little margin on the sale as it is to break even on the mortgage due to our lack of time at this location.
Any advice would be appreciated!
No one knows if this is fixable? We are near Ardmore, Ok.
So far I haven’t found anyone that repairs fiberglass pools other than cracks from OKC to Dallas. We’ve been told by lenders that they will not lend money to a buyer unless the pool is fixed and we are desperate to get the house on the market. My job is relocating to a different state. We’ve also been told we could have issues if we do partial demo (which is the only option I’ve been able to get).
We finally found someone out of Dallas who can repair it. They will cut out the bulge then reinforce it from the underside before laying a new piece to patch and recoating the entire pool. Work and patch warranted for 5 years and 10 years on materials as well as transferable to the new owner. Only $12k �� Still, that’s only a couple more thousand than the quotes I’ve gotten to do partial removals with compaction. Now if we don’t happen to get 10” of rain in one afternoon again we’ll hopefully be all right.
The third option is that it’s technically cosmetic and we list it as is, hoping it doesn’t crack, and negotiate price.
Don't spend the $12,000 if you are selling the house. If the new owners want to fill it in, why pay anything to fix it - it's not adding anything to the value of the home either way. Go with the "cosmetic issue" and that's that. (Most fiberglass pool warranties warrant only that the pool "will hold water")
Do this. You may have to give the buyer the $12K discount or you may come out ahead. Talk with your Realtor what to put in the disclosure.
Well, we disclosed the bulge and had to drop the price $6k, half the cost of the estimate for repair. Everything else checked out ok (pressure test, equipment working).
You came out ahead. Good luck with the rest of your sale.
