In the summer, I have eight pumps drawing liquid chlorine and muriatic acid out of six barrels in three locations. The chemicals are dispensed automatically as required and those requirements can quintuple between opening in May and the heat of July and August. All of this leads to a lot of background anxiety about when barrels are going to run dry. The current practice is to have the lifeguards perform "Barrel Tip Tests" multiple times per day. Grab the barrel with tubes coming out the top by the rim with one hand. If it Tips easily, call Frank. This plan has produced very uneven results.
It occurred to me this morning that, if I knew how long each pump had been running, I would know how much chemical it had dispensed. For instance, my smallest pumps can move 12 GPD. After running 80 hours, I'll be pretty close to the bottom of the barrel. My newest Chemtrol units can keep up with this for me. My older units cannot. Is anyone aware of any kind of resettable device that can display how long a circuit has been live since its last reset? I might be able to use a KILL A WATT for this but the P3 I have resets to zero every time the current is interrupted.
