- Apr 16, 2023
- 64
- Fiberglass
- Hayward Salt & Swim 3C
Hi All, I'm wondering if there's any reason to use a higher ppm for chemicals like CYA or change anything with regards to the Sticky "How do I use Chlorine in my Spa?". The Spa is a 550 gallon, fiberglass, shell that's in-ground about 2/3; i.e. it sticks up a foot or 2 out of ground. It is totally separate from the pool and equipment is in my sig. Because of its 10ft diameter, I haven't purchased a proper cover. I only use a blue solar cover when we're not using it. Should I treat this like a pool or spa? With the heat, I lean toward spa but it is exposed to direct sun during the day. Or really... Am I just over thinking this and get the chemicals to the ranges in the PoolMath app and leave it at that?
