- May 23, 2013
- 13
Inground pool, had a guy come out and install the pump he installed it raised like attached picture. Is this an ok set up? i felt like it would be better with a straight run into the suction versus the elbows with pump off the ground.
What brings this question up and i am beginning to be stumped on this issue.
It doesn't seem i have the pressure on my jets i normally have, skimmers seem weak. however i switched to circulate to skip the filtration and it is churning the water and have tons of power in jets and skimmers. Could this mean i need to replace my sand? some issue with sandfilter? or would this pump being raised as it is causing me issues?
thanks!
signature below is for another pool not the pool with issues.
thanks!
