Import tests via CSV
ctflora
1
Raleigh, NC
Jandy Aquapure 1400
I am moving from a spreadsheet to the Pool Math app, and would really like to be able to import my data. I see there's an option to import test logs from a CSV file, but I cannot get it to work. Every time it tells me that my file has an invalid format. I'm using the suggestion that appears after the failed import as a base, and I still get the same "Import Failed" "Import file was in an unrecognized format" error.
Here's the full extent of my test file:
Date/Time,FC,pH,CYA,TA,CH,Temp,Vacuumed,Notes
2024-08-10 10:00am,4.5,7.9,20,70,330,84,No,
As far as I can tell, it's identical to the first two lines of the suggested format except for the individual numbers. Any ideas why this doesn't work?
Also, is there any reason why the format doesn't also include columns for TDS or Salt?
