I am french, and live in the South of France, my pool (and the pump) are 12 years old. The pump is spanish made (ESPA, Silen 50M), good quality (about $300) for a power of only 0.5HP.
The pump is not leaking, the motor spins without any noise (bearings in good conditions, I suppose), but no flow of water. I dismantled the pump, and figured out the design is similar to some Hayward pumps I saw in some videos. So, the motor spins, and if I block the shaft, the impeller spins freely also. Hence, I cannot unscrew the impeller.
Am I right in assuming the impeller is broken somewhere around the overmoulded thread? What amazes me however is that I cannot pull the impeller off the shaft: if it was broken, I thought it would be free, and would sort of fall off. Have I got that wrong? how come it is stuck there on the shaft, and yet turns freely?
I am ready to cut the impeller into small piecés with an angle grinder, but if someone thinks I have it wrong, I am ready to try something else!
Note: I searched the internet in France, then in the whole of Europe, (to no avail as usual) for the whole day yesterday, and nowhere, except in THIS forum, have I seen any reference to my problem. Hence, I commend the admins for this forum. You are tackling the REAL problems people have in the field, ...
I wish you all a good week end
your ideas and comments are welcome, many thanks in advance
