- Jun 3, 2013
- 12
I've got a 2HP Pac Fab Challenger. Pump stopped working yesterday. When I was troubleshooting it, it was making loud humming sound but not moving. Opened it up and discovered that the impeller is rubbing against the metal ring inside the diffuser. I replaced the diffuser, impeller and shaft seal two years ago and have had no problems with pump until yesterday. When diffuser and mounting plate are removed, the shaft spins easily in either direction. Put diffuser back on and impeller spins half rotation then rubs against diffuser and stops. In the pics you can see the grooves on the impeller.
Any ideas on likely cause for this? Damaged/warped impeller and/or bent motor shaft are my guesses. When I spin the impeller, I can't really see a wobble.
Is there a way to tell if the shaft is definitely bent, and if it is, do I have to get a new motor?
Thanks!
Thanks!
