Edit-update.
With help from a friend we removed the mesh cover.
The water was pretty decent with a slight layer of silt on the bottom and a pile of dead worms in the deep end.
I managed to install all the drain plugs and the DE filter along with the SWG and took return plugs out. No leaks (knock on wood)
Set the multi valve to recirculate and everything primed up nicely and then switched to drain.
Getting the vacuum plate to stay on the skimmer was the most difficult part, but got it going and sucked up some of the debris and stirred up the rest.
The DE filter has done a great job filtering the silt and the waters very clear now.
I'll have to backwash the DE later as the silt has raised the pressure about 5psi.
Just wanted to say thanks for the guidance and it all worked out well.
I've watched long enough opening and closing that I think I can do it with a little help.
I'm on a search for a way to clean the debris off the bottom without going through the pool pump to waste. It seems that the pool pump would lower the water faster than I could get the bottom cleaned.
I was told that I can siphon the water from the pool? I have a side that is lower than the water level, so technically I should be able to do it but I've never tried. Using 1.5 hose, would that generate enough vacuum to actually pull debris out? The guys that have been opening it have an old pool pump they use, but I'm trying to see what I can do with what I have.
As far as vacuum head, is there one better than another? Liner safe. There are a ton on Amazon, and I don't know one from another.
https://www.amazon.com/Milliard-Flexible-Vacuum-Cleaning-Debris/dp/B00IT2VZIC/ref=sr_1_19?keywords=pool+cleaning+vacuum+head&qid=1677021177&sprefix=pool+cleaning+va,aps,127&sr=8-19
https://www.amazon.com/POOLWHALE-Rectangle-Vacuum-Bristles-Connection/dp/B089LKFSKT/ref=sr_1_14?keywords=pool+cleaning+vacuum+head&qid=1677021177&sprefix=pool+cleaning+va,aps,127&sr=8-14
Any input would be appreciated on my siphon idea and vac head.
