My pool has a 4 ft retaining wall. It has been losing a lot of water per day the last few days like probably 3" per day and it's been cooler than the summer when we would lose maybe .5" a day.
Today I went in the opposite side of the retaining wall and there is standing water.
I tried the pool dye technique to check all of the jets. The only ones that look suspect are two of the hot tub returns and when firing the spa up alone there was noticable air bubbles coming from those returns only.
The next thing I checked was the suction side. I have two skimmers and the double main drain piped together, and well as the hot tub main drains. I was able to run the pump fine off both skimmers alone but there is a considerable amount of air, like a LOT when I turn only the main drain valve on on the suction side.
About three hours after shutting off the system the hot tub was down probably 4" and I noticed the backflow preventer for the spa noticable was half way full of air on the return.
I was thinking to leave the system off for 24 hrs to try to isolate if it is one big leak or two leaks. I have a feeling though if the hot tub return pipes are leaking they would only drain down to about the top of the return line, right?
I was considering shutting off the spa valves and running the pool again tomorrow if the pool level has not gone down and then if both continue to drain, I was considering to swim down and plug the main drains with the rubber plugs. This is not going to be easy though as the water level is about 8ft.
One other odd thing I noticed is that when I put the pool in to service mode that on the return side the jandy valve does not completely shut off the Spa returns (the fountain returns are separate). Is it normal for a small amount of water to go to the spa still? The problem is there is no manual valve to shut off the spa returns, only the fountains, so unless I adjust the valve stops i can't run the pool cimpletely isolated from the spa.
Sorry for all of the questions at once!
