Hi. I’ve read a couple threads regarding these units but no clear answer yet. I have a two year old system - just out of warranty.
Noticed my pool started taking on algae. SWG says add salt. I added 20 lbs to my 10kgal pool and bumped SWG up to 80% like I’ve done in the past to boost chlorine in my algae infested pool. Next morning, I tried to turn it down but it was unresponsive (stuck on 80 and a rotating circle). I disconnected it from the control box to reset it. When i plugged it back in, the display went out, SALT started alternating between red and green, but flow is showing good.
I took it apart and zero calcium buildup. What can I do next? Is there anything in the control box that could be the culprit?
1) don’t want to replace SWG if I don’t HAVE to.
2) if I do, then Pentair Intellichlor Chlor IC-30 sucks and I’d probably prefer to replace it, so I’d there a drop in replacement? Or would I have to replace the whole control box and SWG system?
Thanks!
Thanks!
