IC40 - high reading
Candurin
388
South Jersey
Fiberglass
Pentair Intellichlor IC-40
So, I’ve had my salt in the water for over a week (first time using the swcg).
Daily testing with k-1766 confirms that my salt has been between 3600-3800 every day (18-19 drops).
The IntelliCenter reports back with a salt reading from the IC40 much HIGHER (in contrast to all other threads where the IC reports lower ppm readings). My IC40 has reported anywhere from 3900-4700. It has been in the 4300 range for most of the week and right now it is 4700 (just confirmed it is actually 3600 with the TFPro Kit).
Any ideas why the IC is reporting back 1100 ppm higher? Anything I can do to bring it into closer alignment?
Thanks!
No adjustments are possible. The SWCG will generate just fine at that perceived level of salinity. No reason to mess with it.
Enjoy your pool and new SWCG.
