- Jun 24, 2021
- 16,366
- Vinyl
- CircuPool RJ-60 Plus
You are killing stuff!Just did the night FC test and it’s at 15. Still seems like it’s dropping awfully fast.
It does. Well done.16.5 to 16 FC, CC is 0 and water is clear. Guess that means SLAM is done?
Let the FC fall back closer to target range. Turn the SWG on at high target (ish). Mess around and find out with lots of wiggle room to minimumNow what? Turn SWG back on and keep an eye on FC?
Get a good test in blazing sun mid day. (At the first chance). I want to double check @PoolStored agrees before we act, but I'd raise my CYA to SWG levels. We've been splitting duties here and 'too many cooks' and whatnot. Lol. Anywho, Its plenty warm by you and you're going to stay SWG even if this one is toast.At what level do I check CYA again?
Sounds like we need another chef….We've been splitting duties here and 'too many cooks' and whatnot.
It is certainly a way to skin the cat.Wouldn’t a proper overnight gain test (now that we know OP is clean) solidify if the SWG is running at full steam - or is a racehorse with a sprained leg that may need to be replaced?
It is what it is and we get it.Won’t be able to test in the middle of the day until Saturday unfortunately
I'm almost positive you won't be hitting minimum FC also.I’ll assume with an FC of 16 this morning it should hold until I get home this afternoon
Get it at dark for the baseline (being comfortable its still way above min), run the SWG at a high% until morning and see what it made.I’ll check it then and see what my level is
Id squeeze whatever the cell would make for less jug lugging. No matter how many, id rather lug half the jugs than all of them. Plus, you already paid for the SWG FC so use it. Supplement if needed.I guess I’ll just stick with LC until the weekend when I can get the readings I need?
Now what? Turn SWG back on and keep an eye on FC? At what level do I check CYA again?
I'd get CYA to 60, until you can demonstrate that you can maintain FC. That way if you do have to SLAM again, it won't be as bad as doing it at 70 or 80.Get a good test in blazing sun mid day. (At the first chance). I want to double check @PoolStored agrees before we act, but I'd raise my CYA to SWG levels.
Run the SWG on 100% during the test IMO…..Doing so removes a variable as we know what it should produce at 100% and don’t need to extrapolate data down to 90…Thanks all! Somebody turned on the rain switch right when I got home from work and we picked up about 1.25" (not complaining!).
Just went out at 8:50 and did FC test - it's 7.5. Is that crazy for one day to drop from 16 this morning? It was hot and sunny till the clouds opened up around 6pm.
It's right around 9pm now and I'll fire up the pump and SWG on 90% (?) and grab a test in the morning around 6:30am.
I just type 90% into poolmath instead of 100%.as we know what it should produce at 100% and don’t need to extrapolate data down to 90…
Been a long day….i like simplererrerr….ok never mind your point is correct.I just type 90% into poolmath instead of 100%.![]()
Yes. It should have raised FC by 4.2 ppm. Looks like your cell is on the way out.Good morning - did the FC test at 6:30 and it’s at 9.
So that’s a 1.5 increase over 9 hours at 100% output.
Low?
