I have a brand new pool and a little confused on what to expect when controlling the heater (I have a Raypak heater).
I can turn the heater on and off via without issue, but I'm not sure what's supposed to happen though though when controlling the temperature (beyond the obvious). In the iAqualink app it'll save the temperature setting however the heater doesn't seem to reflect that and continues to to say "Remote Pool XX F" on its integrated display with XX being whatever the heater was manually set at when last in manual mode.
What's actually supposed to happen? Should the heater display match iAqualink and update temp on its integrated display to match whatever I set in the app? Or, does iAqualink just power the heater on / off until the temperature i set in the app is registered via its own internal water temp sensors? I suspect the later is the case given that I only see hot, neutral and ground wiring coming from the heater.
Similar question with Spa heat... I can turn on spa heat when in spa mode via the app, though the heater continues to say Remote Pool (though all valves remotely dump that water into the spa).
Im just confused as to what the user experience is supposed to be and I'm not sure if my iaqualink / heater have been wired incorrectly or are operating as designed.
