- Oct 13, 2022
- 7
- Plaster
- Liquid Chlorine
- Hayward Aqua Rite (T-15)
Hi all,
I'm a new pool owner in California. As I learned so much from the community here, I wanted to give back, by registering to the forum and sharing my experience after the first couple of months.
The main challenge I faced was high Calcium Hardness (1000+ppm) in my plaster outdoor pool.
I couldn't find anyone offering reverse osmosis in my area (although both gentleman were super friendly and helpful), nor was I willing to waste over 25000 gallons of water during a drought.
So last summer, despite the various comments advising against using a water softener I gave it a shot (or let's say quite a few shots).
Short version
Before softening:
After treating my pool with 85 cycles on my Kenmore 350 water softener and about 400 pounds of salt:
Long version / main challenges
1. move water - Hard pool water needs to be pumped out of the pool, through the water softener and back in the pool
It was an adventure, I learned about pump flow rates and discharge head, about venturi elements and salt bridges and not to forget hose vs. pipe threads
Next time I will for sure try a high pressure pump.
Happy to provide more details to anyone interested.
Short version
Before softening:
CH: 1000+ ppm
Salt: 2600 ppm
CYA: 100 ppm
CH: 240 ppm ( -760 ppm hurray!)
Salt: 3600 ppm ( +1000 ppm)
CYA: 60* ppm (I noticed a reduction in CYA but I also experimented with the Bio-active cya reducing bacteria, so I can't say if it can be attributed to the softening process)
- pump - I should have used my pool pump, but I wasn't keen on the electricity bill, nor on the plumbing it would have required. I ended up using a 1/4 HP submersible pump from home depot (don't do this). I found out the hard way these pumps are good for high flow rates with large pipes, but do not generate a lot of pressure (<6PSI). My softener needed at least 7 PSI (iirc) to be able to regenerate (rinse the resin beads in the tank to flush out the calcium with salt brine), which my pump couldn't do. Also the pump housing fully corroded from the salt in the pool.
- pipes/hoses.- I used 3/4" garden hose for the feed line (pump to softener) and the return line to the pool. This is not great for submersible pumps as it restricts flow (which becomes increasingly important after a while). I ended up moving my softener right by the edge of the pool to minimize the hose length. (and I learned about hose thread and pipe thread NPT standards)
- I used my household Kenmore 350 water softener. I removed it from the house water supply and added in a bypass. I moved it closer to the pool to minimize hose length. (the water softener is back in the house and working excellent)
- testing - the biggest challenge is knowing if the water softener is actually working well.
When the softener was working well 1000 ppm pool water went in and 5-10 ppm water came out. However initially I wasted endless cycles where water was flowing without it getting soft.
I ended up using Calcium hardness test strips both 0-1000ppm and 0-400 ppm range to measure the output of the softener at regular intervals (initially 10mins).
I also used a Taylor K-1770 test kit to measure softening progress in the pool itself every 10 cycles.
- the softener has an input water hardness setting (expressed in grains of calcium 1g = 17ppm), and would automatically regenerate after a certain volume of water had passed through. the softener would be saturated long before that. (hence testing was important to discover the trends)
- auto regeneration failed because of the lack of pressure my pump could generate. I switched to city water (>40psi) for every regeneration cycle and then back to pool water. This is unfortunate, because this brine water drains to the sewers (should ideally be pool water) and took manual effort.
- I used about 400 pounds of salt. Don't add a lot of salt at once. The salt level dropping is a key indicator things are working.
- pool went from 1000> 240 ppm in 85 cycles using 400 pounds of salt
- in the process I added about a 1000 ppm of Salt back into my salt water pool
- Every cycle removed close to 10 ppm of Ca from a +-27000 Gallon pool (in absolute numbers thats about 16.000 grains/cycle)
- I used about 400 pounds of salt to remove a total of 1.2 M grains. That's about 3000 grains removed per pound of salt which is slightly above the Kenmore rated minimum salt efficiency.
- My pump was able to achieve about 200 Gallon per hour flow rate (and 260 Gph with shorter hoses)
- Because the total pool hardness reduces with every cycle, the amount of water that has to be treated to remove the same amound of Ca increases with every cycle. The first 10 cycles (pool at 1000ppm) each lasted an 1hour, treating 2000 Gallons, before needing to regenerate. The last few cycles (pool around 300 ppm) lasted around 3 hours, treating about 6500 Gallons. Regeneration cycle duration is fixed with the excpetion of extra rinsing and backwash etc, you can disable all of those to reduce the regen time.
- The pump consumed about 55 kWh of electricity in total.
