You are so helpful!!! The server is telling me my images are too large to upload. I'm going to shrink them and try again. Stay tuned!1. You have a Paramount In Floor Cleaning System (IFCS). Part 1 contains the valves to cycles through the various in floor cleaning zones.
Powerful In-Floor Pool Cleaning System - Paramount Pool & Spa Systems
A pool built with a PCC2000 in floor pool cleaning system is virtually maintenance free, reliable, and makes owning a pool simple.www.1paramount.com
2. That is a Paramount leaf catcher.
EDC - Paramount Pool & Spa Systems
The largest pool debris canister on the market. Collect more leaves and debris before it reaches your pool pump. The high capacity Equipment Debris Canister (EDC) is designed to capture more debris, reduce cleaning time andwww.1paramount.com
3. Post wider pictures showing all of your equipment pad so I can understand where all the pipes go.
I don't have a spa. I did play with them a bit and learned B is the aerator lol!The second pump is for spa jets?
Give a clear head on pic of this manifold showing all the pipes. You have four pipes going into the ground. Pipe A may feed water to the IFCS valves (1).
Do you have separate returns from the IFCS pop ups on the floor?
You need to close and open A, B and C vales and see what changes with your pool return water flow.
@proavia is familiar with how IFCS is setup and may have ideas.
I don't know what a return is....
You're amazing! Thanks for your help!!!Water comes out of your filter following the red water path towards C. All the water is your RETURN water. It then has four possible pipes it can RETURN to the pool.
Note that the fist pipe marked in purple is before valve C. So water will always flow to it.
My guess is the three pipes to the left of valve C do some things with your IFCS. If you turn the handle of C up to the left 90 degrees it will shut off the water flow to those three pipes and just leave water flowing to the purple pipe.
The way the valves are set in the pic RETURN water will flow to all four pipes from the filter.
Will do when I get home. Just left for work. If you're seeing a black box near the pool, not the pump, that's the pool light.Show us a picture of your timer enclosure with the door open.
Show us pics of the pool from a few different angles.
It appears there was additional equipment to the right of the filter. Maybe a long removed heater or heat pump?
The tan pump is either for a water feature or for the infloor system. No idea why infloor 9f that brand is sometimes plumbed with a separate pump and unfiltered water. Just makes no sense.
Below the skimmer from the inside of the pool, is there an open pipe below it? That would indicate the possibility of a venturi type skimmer. If there is an open pipe below the skimmer or below where the leaf catcher is, check for water flowing back into pool when black pump is on. Also check when tan pump is on.
Are there any additional covers in the deck besides the leaf catcher and skimmer? Auto water leveler? Open them the post pics of the internals.
Suction side is probably one pipe from skimmer to pad and other from bottom drain thru leaf catcher to pad.
The two 3/4" pipes without valves are weird - most of the time they put valves on them.
Once we see a pic of the timers and pool, we can better determine what you might have.
No additional equipment next to the pump. This is the top of the Hayward pump which I didn't even know this opened and was a little computer!!!It appears there was additional equipment to the right of the filter. Maybe a long removed heater or heat pump?
I took apart the infloor cleaning system yesterday and learned it's a Paramount 2000.The tan pump is either for a water feature or for the infloor system. No idea why infloor 9f that brand is sometimes plumbed with a separate pump and unfiltered water. Just makes no sense.
There is a pipe below the skimmer. The Hayward is running and to me it feels like water is being sucked INTO the the pump, not out into the pool. Which....at our old house my husband was across the country and I found a dead squirrel floating in the skimmer. So I had to call a neighbor to come get it out. So I'm kind of traumatized and weirded out about sticking my hand in the skimmer. But I did it!! Lol!Below the skimmer from the inside of the pool, is there an open pipe below it? That would indicate the possibility of a venturi type skimmer. If there is an open pipe below the skimmer or below where the leaf catcher is, check for water flowing back into pool when black pump is on. Also check when tan pump is on.
Here's what's under the other cover. What is it?
Yes we cleaned the filter before we refilled, after we drained.Have you cleaned the filter ? It's likely the last people hadn't for a long time.
Yes, using pool math. Log is as follows:If your water is still cloudy, your SLAM Process isn't complete.
Are you using PoolMath? If not, you should be. If you are, share your PoolMath logs here so we can see your test results easily.
It doesn't seem to have water coming out. It's difficult to tell with the pump running. I will check again tomorrow. But it felt like it just had water being sucked in.For the skimmer, you said there is a pipe below it inside of the pool itself. Does the pipe on the inside of the pool below the skimmer have water coming out of it - even just a little? That pipe shouldn't have any suction/water being sucked out of the pool.
The pop ups come up with the black pump on or off. They come up with the tan one off or on. The tan pump is a cartridge filter. The black is the Hayward pump. The small round thing, with the missing psi gauge, is the IFCS.Do the popups for the IFCS pop up with black pump on and tan off, or only with tan pump on (black off)?
I will do that tomorrow around 4pm Arizona time.Some much closer pics looking into the pool with all equipment off (still water) from lots of different points along the pool would help to see where other pipes in the pool are.
They're not always on. There's the yellow timer. Below that is several circuit breakers. I don't know which controls which. I don't even know which way off/on is because the words are worn off. I push those on/off until whatever I want to turn on or off works.I am still puzzled by the two 3/4" pipes without valves.
In the enclosure with the two yellow faced timers, both timers are always on. How do you turn on the tan pump.
That I should be able to figure out myself by playing with it.The black pump is controlled by the small black timer enclosure as the pump is a variable speed. On/off times, pump speeds and schedules can be set there.
The concrete pump to the right of the filter previously had equipmemt on it. My guess would be a heater that was long removed. Given the plumbing layout - especially the outlet from the filter to the first Jandy valve - a heater may have originally been plumbed in there.
In the enclosure with the two yellow faced timers, both timers are always on. How do you turn on the tan pump. The black pump is controlled by the small black timer enclosure as the pump is a variable speed. On/off times, pump speeds and schedules can be set there.
