So this Pump Speed Setup page on the iAquaLink Android app is not optimal. I can set the RPM's and duration for the quick clean command, the timed run command, and a few others. But you can't then simply start the quick clean or the timed run from the app. You have to go outside and push the iQPUMP01 buttons to do a quick clean or timed run. What's the deal with that?
So you can do a "set custom speed" where you enter an arbitrary speed and duration. Sure you can accomplish the same thing, but then you have to remember the settings and risk putting a bogus speed value in. I'd really rather just push a button on the iAqualLink app to run my saved command profile. If you do the "timed run" from the iQPUMP01 it is even worse because you can't stop that operation from the app (it gets locked out as being in "service mode"). Thanks for that.
Do they ever make improvements to this app? It has had this same exact lame interface since I installed the pump last year.
