Hi Everyone, thanks for help. New pool owner here. I started with half empty swamp pool in March. I refilled pool and CYA level was 80. With this website and forum I SLAMed the pool and it went great. Loving my pool which is clean and clear.
Two questions.
1) 4-6 weeks ago we had a lot of rain. I drained 4-6 inches from the pool over a few weeks. Afterwards CYA was 60. I was surprised at drop but pleased. I had to drain 2 more inches after that, and since have filled pool often with well water due to typical all day long blazing NC sunshine in the summer. Pool temps 85 degrees. In the last week I’m losing a lot of FC each day 4 or even 5 ppm but pool looks great. Today I rechecked and CYA is down to 30! How did that happen???
In case you need it. Tonight’s check FC 6 CYA 30 TA 30 pH 7.6 before new chemicals.
2) When I opened pool pH was low ( in March) and I added pH UP. TA and pH went up. TA has been consistently 70-80 and pH 7.6 ever since with no change. My nephews are heavy splashes but I was very surprised to see today’s TA suddenly low at 30 but pH exactly the same as always at 7.6. Why didn’t pH change too when TA went down.
Thoughts? I test FC everyday but confess i check other tests only every 2-3 weeks
Two questions.
