The previous owner of our house had a spa which he removed and covered its place with concrete. Attached is how piping looks like, and my guess is one of the highlighted pipes was for the spa (or can they both be for my pool?). I am trying to find space to install an SWCG (Universal 40). So I though that if I could figiure out which of the highlighted pipes is for my pool, I can cut UL40 into it. As you can see on the picture, one of pipes has a valve. I am not sure what it was for, but it appears to be broken as no matter how much I twist it, it doesn't close. Are these valves usually installed on spa pipes? Can it be a solid indicator it is a spa pipe and the other one if for pool? Is there any other way to tell for sure which one if which?
