Hi All,
Just finished building our first ever pool a month ago. I'm still waiting on the PB to finish hooking up gas to our heater, so we haven't technically had a "pool school" yet to learn how to use our equipment. However, since I plan on maintaining the pool myself I have already dug into many of the features of the iAqualink system, but I can't seem to figure out how to run two different speeds at different times of the day. The after plaster care portion of our start up has been completed and when the pool guy doing the after plaster care was here on his last visit he mentioned that I could program different settings for my VSP pump.
We have an 18" raised spa overflowing into our pool. In order to get a uniformed sheet of water flowing into the pool from the spa they have the pump set at 3450 rpms with the filter pump running from 8am-6pm daily. The plaster care pool guy was telling me that I could set a schedule to where the pump could run at a lower speed during the day while we're at work (8am-5pm). Doing so will still keep the pool circulating, but the water coming over the spa into the pool would be at more of a trickle than a sheet of water. He said that we could then have a different program setting that would bump up the speed to 3450 rpm, say from 5pm-8pm, that would push the water from the spa into the pool in a sheet like we like to see it, once we are home from work.
The problem I'm having is I can't see where you would do this in the iAqualink menus? I see that you can program different groups, but it looks like that is used more for different dates of the year than different times of the day? Can anyone point me in the right direction?
