I am preparing to SLAM my pool for the first time, due to (hopefully, green) algae that's been growing on surfaces for a couple of months now. The water is (and has been) clear enough during our recent summer, possibly due to the benefits of the UV light that is installed in my system. I was also using low doses of a Polyquat 60 algaecide all summer, which I hoped would give me sufficient protection against algae on top of 1ppm FC levels.
I think what went wrong is that my FC levels dropped too low on multiple occasions during the summer. I use a semi-automatic (semi-manual?) liquid chlorine feeder, which requires me to adjust the running time to get the "right" level of chlorine. The aim was to be at about 1 to 2 ppm, supported by the UV light, because chlorine is irritating to my eyes and lips. This worked fine last year. But something was causing the FC to drop lower this summer, and I was too slow to get onto it. (I'm not sure if the chlorinator is feeding more slowly, or the quality of the liquid chlorine has dropped, or something was consuming more of it.)
A few days ago, I did the overnight FC test using a FAS-DPD kit, and it is losing well under 1ppm overnight, but there is undeniably algae growth on surfaces, especially in nooks and crannies.
I have read up about the SLAM process and am preparing to do it, but am not sure how to handle the algae that got into the retro-style pool light, which was fitted two years ago by the guy who replastered the pool (see photo). Is that cover not meant to be sealed? Can that be opened up (after disconnecting the 12V), or do I need to do a partial drain of the pool to access it?
Any help is appreciated.
