Hi.. i have a 18' doughboy silver interlude 52" it is completely filled up...trying to bond pool and i have 6ga wire(they only had 8ga in 50ft rolls so i went with 6ga) question is installer put pool wall bolts behind upright...my top rail and covers are resin...the uprights are resin the base wall ring is metal...question is can i remove the resin upright at top or bottom to get room to attach on to wall bolt i can kind of see in there and it looks like there is enough threads as to not having to remove the wall nut it looks like enough threads to add a lug and another nut to existing bolt. Sorry for long post just not sure if ok to loosen a upright post if pool is full ..lol.
