I’m struggling to balance my pool water. I performed a SLAM for almost a week and passed the OCLT, the water still won’t hold chlorine under sunlight, but looks clear and crystal.
This made me question my CYA level again. Both Leslie's test and my own showed a reading of around 50 before, and all tests were conducted indoors.
Today, I decided to compare indoor vs. outdoor CYA test results and discovered a significant difference:
Picture #1: Indoor Test – The black dot disappeared when the solution level was slightly below 50 (around 47-48).
Picture #2: Outdoor Test – When I took the same tube outside under direct sunlight, the black dot became visible again.
Picture #3: Outdoor Test - I continued adding the solution until the black dot disappeared again, and this time, the reading was slightly below 30.
Base on this situation, do I need to add more CYA?
30000 Gallon, pH: 7.5, TA 125, CH 270, Salt: 3400, Water Temp: 73F
Appreciate any idea.
