Since you are losing more than 1 ppm FC overnight, you need to do the shocking process, but you high cya really makes that impractical now. I would continue to lower cya, before focusing on the shocking.
linen said:Since you are losing more than 1 ppm FC overnight, you need to do the shocking process, but you high cya really makes that impractical now. I would continue to lower cya, before focusing on the shocking.
I would guess yes, unless the ph was high before you brought it to shock level. Either way, don't adjust until you are below 10 ppm FC.bigmoguls said:pH>8, not sure if this is due to the high FC level or not
Still a little high for a non swg pool. It is manageable, but it might be best to get it down to 50 ppm now.bigmoguls said:CYA=65...WOOHOO! Now I can get on with the show.
Isaac-1 said:Like linen said, maybe still a little high, but I would not worry about it given we are likely getting into the rainy season
Water crystal clear? If yes then,bigmoguls said:Tested FC level last night was 14.5, this morning it is 14.0. CC=0.0
I think I'm good to go.
linen said:Water crystal clear? If yes then,bigmoguls said:Tested FC level last night was 14.5, this morning it is 14.0. CC=0.0
I think I'm good to go.![]()
