How long will Intex 2650 pump last?
Jun 6, 2016
44
Asheville nc
Good morning. I have used my Intex 2650 pump with swg for three seasons. At the end of this past season it would run for about one minute then shut off. I cleaned everything with vinegar as advised with no change. Any ideas on next steps? Thank you.
I have just the SWG from intex and it seems that that is about the life span of the plates. Are you getting the code for low salt? If not is it giving you any codes when it shuts off? You might get lucky and be able to get the replacement plates from intex. If not and the pump and I am assuming sand filter are still good you can get just the SWG for around $100 off amazon.
