David, my battery is low and I'm about to turn-in for the night.
So I don't want to leave you hanging. I haven't seen your test results yet, but I'm assuming your FC must be very low right now or non-existent. Would that be true? Also wondering if your CC level is elevated. So there are two options to consider here: Either you simply have organics/algae that is consuming FC very quickly and you need to stick with a SLAM, .... OR with no CYA and FC depleting exceptionally fast, your CYA may have converted to something else like ammonia. With no tests I can't tell for sure. But I would still consider conducting this test first:
- Add only enough bleach to get your FC to 10. Test it again in 10 minutes. If your FC held between 5-10, then increase it to 12, then add stabilizer for a target of 30, and perform a SLAM (link below) like normal.
If your FC fell below 5 after just 10 minutes, increase it back immediately and test again in 10 minutes. Continue this cycle until the FC holds after 10 minutes.
As you can see, either way it's very important to stay on-top of the FC testing in this early stage - every 10 minutes at first. It's required to allow the FC to hold better and overtake what's in the water. Now if the 10-min drill doesn't work after a couple hours, you do have the option of doing a partial drain to remove some of the bad water if you prefer to help kick-start the cleaning process a little better. Some situations find that a partial water exchange might be more cost-efficient at first. But you would still need to SLAM once filled back up. If water exchange and time are a factor, I would go right to the 10-min drill first. But make sure to have a good amount of bleach ready when you do.
David, you'll need to watch the FC very closely for the first couple hours or so until it breaks this "fever". Don't add stabilizer until you see the FC is holding on its own past 10 minutes. Let us know if you have any problems or questions.
