I have a 18 month old IG 23K non SWG pool, pebble tech finish located in Houston TX. (think that is all to note). I test my pool chemicals daily and for quite a while now have basically been able to predict the readings. Well the past three days we got a lot of rain, about 7" so I was expecting that some of my figures would have changed. Test results yesterday (post rainfall)
FC 4.0
TC 4.0
PH 7.6
TA 65 (keeping low due to PH rise)
CH 225 (typically keep closer to 300)
CYA 70
I decided to raise my CH up by adding 12 lbs to the pool and running the pumps for 4 hours. Today, 24 hrs later and no rain, tested the water again and CH levels had not changed, but more surprisingly my FC/TC are reading zero (other test results unchanged). I re-tested from another spot in the pool and no change. My typical chlorine usage has been less than 1 ppm a day and I have no signs of algae or any cloudiness to the water. My question is, could somehow adding CH to the pool have an impact on my FC levels? Any idea what is going on here? BTW - I used the TF100 test kit that is only about 3 months old. Greatly appreciate the help.
FC 4.0
TC 4.0
PH 7.6
CYA 70
