Not sure if this is for "The Deep End" or "Just Getting Started"...
We all need to visit pool school now and then. I know very little about SWG’s so I have some questions after reading the article about Water Balance for SWG’s in pool school.
Will CC’s not form in a SWG pool? What about pools that require winterization, would you still shock a SWG then? The phrase "never need to routinely shock" this applies to any properly balanced pool, yes?
If you are going to leave the SWG pool unattended for a week or so, is it more advisable to leave the equipment running, or shock and turn off equipment (assuming no one can check on things for you).
Once your salt is in and SWG is running, do you still have to add CL? Or does the SWG put it in? I guess I really don’t understand how they work....
Why does SWG demand a higher CYA level?
Thanks all you pool guru's for helping us all understand things better.
