I know. Surely this has been covered, but I cannot quite find the answers I need.
I have an Intex sand filter by Hayward, model sf 70110. (above ground, btw)
The motor that came with it, 1500GPH / 25GPM, same model #, has seized. It was rusted solid. I couldn’t even get the screws out to try to fix it. I threw it away.
The filter specs show GPM-30, which I think is a little weak for a 10,600G pool. It was often cloudy and vacuuming was really a chore.
My problem is this- I can find no information suggesting if I can go with a higher GPM or not.
The filter says Maximum Working Pressure- 30PSI. Does that mean that’s all it can produce with the original pump, or is that all it can take?
Even if that’s all it can take, pumps don’t show PSI.
The next problem is, the next step up that I’ve been able to find is around 2400. That’s a pretty significant jump. Is that OK?
I’ve seen Amazon reviews for 5000GPH pumps on pools like mine. They said it worked great, but they never say what model filter they have.
I’m so lost. I’ve been researching this for 2 weeks and I’m more confused now than when I started. I almost ordered the 5000GPH, but 12hrs of reading later I don’t know whether to scratch my watch or wind my butt!
Thanks for your time.
Finn
Finn
