If i don't run filter for 24 hours there is a green hue all over the bottom of pool and on the ladder mat. When I check my chemicals the chlorine level is high. Yes, I use the strips but I also have the HTH system with the drops.
My alkalinity is high, Ph is normal, my hardness needs some increasing, CYA is on the money.
Also, and I don't know if I need to put this on a different forum - the green algae that collects on the floor, when I vacuum them they seem to go right through the filter and the return is cloudy. I backwash after each vacuuming and rinse, always.
Some seasons the pool just gives me a headache, and this is one of them.
Thank you
Thank you
