How can I schedule an Aux VSP w/iAqualink?
azpooldood
6
Phoenix, AZ
I have a negative edge trough pump that I need to be able to turn on/off without turning the main filter pump on so when we swim we can keep the overflow trough from overflowing without paying to have both pumps on.
So my 2nd VSP pump is set as a AUX pump but I can’t figure out how to schedule it to run multiple times/day. I don’t want it to run from 4pm-7pm and I only want to blast at high speed for a short time to activate the floor popups.
Any pointers on this? With the Filter pump I can set total duration and then a couple of VSP Speeds within that range. With an Aux pump how does this work?
Thanks!
If you can add it to your schedule what is the issue? Just schedule what you want. I don't have 2 pumps so can't check in my system.
My Aux pump schedule actually seems to be working, however I've noticed that when my Aux pump kicks on, I don't see that it's on in the iAquaLink phone app. I have to go to the "Web" app and click Status to see that it's running. Any ideas why?
The aqualink phone app is very buggy. Never trust what it says and use the web link. Mine crashes 2 times out of 3.
Reactions: dfwnoob
