Houston Build
Jan 8, 2017
19
Houston, tx
Getting bids on build and this is what we want to go with besides some minor changes. Wife doesn’t want sport pool so we will probably go 3.5 to a 7 ft deep end (thoughts on 7 vs 8)? Also want to make it a little wider. Thoughts on equipment? I’ll take all the help I can get
Dimensions Are 39x17sih
Spa is 9x7
equipment
jandy 580 cartridge filter
Jandy pHpm. 2 hp pump
Jandy 2 hp flow pro
Polaris 280 with a PB 460 pump
Jandy JX1 400 NG heater
Glacier cooler
Jandy 1.5hp spa blower
Rainbow 320 chlorinator
Aqua link
Two Jandy water color LEDs
One Jandy water color LED for the spa
Unfortunately, I can't see the image well enough. About the only thing that catches my eye is the in-line chlorinator (pucks). You may already know they are not intended for long-term/daily chlorination, but of course the installer and pool store will never tell you that. So at this point you'll either manually chlorinate each day (adding some liquid chlorine or bleach) to the water which is no real big deal, or if you're into automation and trying to get away from adding chlorine manually, installing a Salt Water Generator (SWG). Your call really, just wanted to make sure you had that noted. Have a nice weekend.
The Rainbow can come in handy when you are away from home or when you know your CYA (stabilizer) level is low enough to handle more CYA from tabs/pucks. But when your CYA is at the height you want it, you'll be using regular bleach (i.e. HEB's Bravo or Walmart's Pool Essentials) unless you install an SWG. An SWG uses salt to create chlorine, so it's chlorine either way. Just a matter of preference. Some builders try to steer some buyers away from SWGs claiming excessive corrosion or damage to nearby stones/coping, but most of that is unfounded. If you have no issues with adding some bleach every evening when you test you water anyway, then it's not even an issue. That's what I do. :)
I would go 8 feet. 7.5 feet is considered minimum for diving (even if you say no diving, people will).
Seems like a lot of pumps. My pool has 2 waterfalls and only uses 1 variable speed pump.
I would lose the water powered cleaner and get a robot.
Make sure you get the full iAqualink that you can program from the web interface.
Have you talked about a saltwater pool? Really the only way to go anymore.
WaterColor lights are awesome good pick!
Also suggest 2-3 floor returns, 2 skimmers and at least 4 wall returns in the pool plus whatever the spa has.
Check my sigline I have all Jandy equipment.
