Uhhello
207
Tucson
Hayward Aqua Rite (T-9)
Went out this morning and checked the cell panel only to see hot. That's a first. Flashing generating light and 'hot'. Cycled off to on and it cleared. Double checked the plates but they were pristine. Guess I need to keep an eye on it.
Edit. Hot warning back on when I came back home tonight. Flashing generating light and 'hot'.
Off back to auto reset it and stayed off. Readings with everything functioning normally.
3300
91
25.5
6.96
40p
AL-0
r 1.59
t15
Can you shade that area? Is it in direct sun?
It's not hot. The cell is reading 86 degrees. It is in direct sun but this is a brand new cell and the last one never had this issue. I will get a full button readout in the morning.
Is the SWG control panel in direct sunlight?
Here in the desert southwest, pool equipment - especially the electronics - needs shade.
Worth checking the thermistor too - as Marty suggested.
Reactions: Uhhello
If it is HOT water temperature, that is normally a thermistor in the cell. But a new cell. Is it an OEM cell?
This is the 5th year with current setup/ no shade. Only change is the new replacement cell. Might be a cumulative effect though I guess.
Reactions: proavia
I also have the T-15 and am getting a HOT message. Could it be from the excessive heat we are having here in AZ? The sun is on the SWG in the morning but not for long. The last 2 days the outside temp has been 119F and the pool does get full sun.
