Seems to be lots of variations on filter cycling between brands and online these days. My spa has a Balboa VS pack, which only allows the choice between 1 day cycle, 1 night cycle, or 2 cycles 12 hours apart. The default is two cycles 12 hours apart, 2hr duration.
My question is, is it advisable to go to 1 night cycle for 4 hours, which leaves the tub with no flow for 20 hrs and the does the filtering and heating all at once?
Reason I ask is we have time of use electricity and the night time rates are much lower than the day. Without being able to alter the time between cycles (locked to 12 hours) with 2 cycles a day, one cycle will always be in the high electricity rate zone. The one cycle would be the same filtering time (4hrs), my only concern is the how long the tub will sit with no flow at all, compared to the 10 hrs no flow with the two cycles a day. Does anyone else use night cycling only? any water quality issues?
Thanks!
Thanks!
