Yesterday I noticed significantly less volume of water returning to pool from waterfall, checked pump and there was a hissing sound and filter PSI at 30 (instead of normal 20). Water flow was at 60 gpm instead of normal 80 gpm. Turned it off and backwashed it. No hissing sound. Re-set to Filter and it was fine (I think).
Today, same thing. This time, when I backwashed, there was water returning to pool from waterfall while backwashing. Not much, but still... This time, when I re-set to Filter, it was a minute into priming and doing OK when I hear a burst like when a bicycle tire punctures, and then the hissing and elevated PSI. I turned off. Try again, and this time I get the burst after a few seconds, then hissing, etc. No water leaks. It's off until I figure out what this is.
I cannot tell if the burst and hissing is coming from the pump or the multiport valve (Hayward Vari-Flo SP0715X62).
I don't know if This is related or not: Last week I swapped out the pressure gauges (1 on the valve, 1 on the sand filter). They were over 7 or 8 years and seemed inaccurate. Replacements were Haywards.
Does anyone know what this is, and how to fix it?? Thanks!
