So I started with this pool in May when I purchased this home. Because I wasn't moving in immediately I hired a pool company to temporarily take care of the pool. That was a disaster as all they wanted to do was dump piles of unnecessary chemicals/algecides in the pool. The did note that the CYA was high (140) and wanted to do a complete drain and refill. For numerous reasons I didn't want to do that but rather some strategic partial drain and refills, I'm on a well. So over the last couple of weeks I had done several partial drains/refills. First partial drain got me down to 110-100 range. I just finished another small drain yesterday and it tested at ~80. So success! Obviously the first key to success was to stop putting tri-chlor tablets in the feeder. I switched to the liquid chlorine method and have been manually testing/dosing. Pool company was fired a few weeks ago.
So my question is do I do another drain/refill cycle to keep reducing my CYA or just let it go? I know the CYA can't increase because I'm not adding any more. I tested FC after the drain and it was low as expected (FC=4). I just added more chlorine to bring it back into check for the range of minimum FC according the chart. My current Ph is sitting right at 7.8, it seems to sit there. Pool is currently clean and clear. Just want to get this under check to reduce amount of chlorine required. It seems like I am moving in the correct direction.
