Good afternoon! This is my first post on TFP. This is only my second summer owning my pool. It was completed in November of 2020. My CYA is currently high. The last water test we got from Ace showed the CYA at 105. Today, using my Taylor K2005 test kit, my results were over 100. Using the diluted CYA test method I found on the TFP Forum my results using the Taylor kit was 160. I honestly have no idea if I done the test correctly. Should I consider partially draining and refilling my pool? Or just let the rain works it's magic. We are currently getting summer thunderstorms almost everyday. I believe the high CYA is from the Chlorine tablets we have been using since the pool was completed. We plan on making the switch to liquid chlorine. I shocked the pool last night so that is the reason for the high chlorine in the test results below. The test results below are from today using my Taylor test kit. In case you are wondering why I shocked my pool, everyone I talked to said you should shock once a week when the water is warm and/or during heavy use. My water is currently 92 degrees. I used Super Shock It 73 we got from Ace. Consider me a newbie in pool ownership. I have been so confused as it seems like everyone I speak too tells me something different. Any help is appreciated. Thanks!
FC 10
TC 10
CC 0
PH 7.6
TA 100
CH 450
CYA 160?
FC 10
TC 10
CC 0
PH 7.6
TA 100
CH 450
CYA 160?
